By michaele6
#85131 i am able to connects to my wireless but changing status on pin2 does not send a message out
so i am trying to prove if this is a push issue or a local issue , so can some one help me with modifing the code so it turns the builtin led when the reed switch is closed , to confirm the hardware and pins are correct
// PushingBox scenario DeviceId code and API
String deviceId = "v8D7383561A3C58";
const char* logServer = "api.pushingbox.com";
char* ssid = "ub1xcv";
const char* password = "mypassword";
int reed_switch = 2;
boolean previous_doorStatus=0;
Serial.begin(74880);
// Sending a notification to your mobile phone
// function takes the message as a parameter
//sendNotification("Hello World from ESP8266!");
pinMode(reed_switch, INPUT);
previous_doorStatus = digitalRead(reed_switch );
void sendNotification(String message){
Serial.println("- connecting to Home Router SID: " + String(ssid));
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("- succesfully connected");
Serial.println("- starting client");
WiFiClient client;
Serial.println("- connecting to pushing server: " + String(logServer));
if (client.connect(logServer, 80)) {
String postStr = "devid=";
postStr += String(deviceId);
postStr += "&message_parameter=";
postStr += String(message);
postStr += "\r\n\r\n";
Serial.println("- sending data...");
client.print("POST /pushingbox HTTP/1.1\n");
client.print("Host: api.pushingbox.com\n");
client.print("Connection: close\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
client.stop();
Serial.println("- stopping the client");
// read the input pin:
boolean door_status = digitalRead(reed_switch );
//makes sure that push notification only on door open
if(door_status != previous_doorStatus && !door_status ){
sendNotification("Door has been opened");
previous_doorStatus=door_status;
delay(5000);
By survivingwithandroid
#86360 I wrote a tutorial about how to connect ESP8266 to PushingBox. It describes step by step how to do it. It may help you:
https://www.survivingwithandroid.com/implement-iot-notification-system-using-arduino-pushbullet/
Let me know it is helpful
