I am implementing a web server from the esp8266 in access point mode (so with no external wifi conenction). i want to show a chart on the web page and am trying to do this through an html variable that has a javascript file source. i have saved the js file to spiffs. the web page resolves however no chart appears, only the text in the html variable. Any ideas?
Thanks
include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include "FS.h"
const char* ssid = "ESPWebServer";
const char* password = "12345678";
ESP8266WebServer server(80); //Server on port 80
String getContentType(String filename); // convert the file extension to the MIME type
bool handleFileRead(String path); // send the right file to the client (if it exists)
const PROGMEM char* s = R"foo(
<!DOCTYPE HTML><html>
<body>
<h1>Hello world</h1>
<canvas id="myCanvas"></canvas>
<script type="text/javascript" src="script.js"></script>
</body>
</html>
)foo";
void handleRoot() {
server.send(200, "text/html", s); //Send web page
Serial.println("");
WiFi.mode(WIFI_AP_STA); //hotspot and client
WiFi.softAP(ssid, password); //Start HOTspot removing password will disable security
IPAddress myIP = WiFi.softAPIP(); //Get IP address
Serial.print("HotSpt IP:");
Serial.println(myIP);
SPIFFS.begin();
server.onNotFound([]() { // If the client requests any URI
if (!handleFileRead(server.uri())) // send it if it exists
server.send(404, "text/plain", "404: Not Found"); // otherwise, respond with a 404 (Not Found) error
server.on("/", handleRoot); //Which routine to handle at root location
server.begin(); //Start server
server.handleClient();
String getContentType(String filename) { // convert the file extension to the MIME type
if (filename.endsWith(".html")) return "text/html";
else if (filename.endsWith(".css")) return "text/css";
else if (filename.endsWith(".js")) return "application/javascript";
else if (filename.endsWith(".ico")) return "image/x-icon";
else if(filename.endsWith(".png")) return "image/png";
else if(filename.endsWith(".jpg")) return "image/jpeg";
else if(filename.endsWith(".gz")) return "application/x-gzip";
return "text/plain";
bool handleFileRead(String path){ // send the right file to the client (if it exists)
Serial.println("handleFileRead: " + path);
if(path.endsWith("/")) path += "index.html"; // If a folder is requested, send the index file
String contentType = getContentType(path); // Get the MIME type
String pathWithGz = path + ".gz";
if(SPIFFS.exists(pathWithGz) || SPIFFS.exists(path)){ // If the file exists, either as a compressed archive, or normal
if(SPIFFS.exists(pathWithGz)) // If there's a compressed version available
path += ".gz"; // Use the compressed version
File file = SPIFFS.open(path, "r"); // Open the file
size_t sent = server.streamFile(file, contentType); // Send it to the client
file.close(); // Close the file again
Serial.println(String("\tSent file: ") + path);
return true;
Serial.println(String("\tFile Not Found: ") + path);
return false; // If the file doesn't exist, return false
}this is my script.js file in saved in a data folder in the sketch folder
var myCanvas = document.getElementById("myCanvas");
myCanvas.width = 300;
myCanvas.height = 300;
var ctx = myCanvas.getContext("2d");
var myVinyls = {
"Classical music": 10,
"Alternative rock": 14,
"Pop": 2,
"Jazz": 12
function drawLine(ctx, startX, startY, endX, endY,color){
ctx.save();
ctx.strokeStyle = color;
ctx.beginPath();
ctx.moveTo(startX,startY);
ctx.lineTo(endX,endY);
ctx.stroke();
ctx.restore();
function drawBar(ctx, upperLeftCornerX, upperLeftCornerY, width, height,color){
ctx.save();
ctx.fillStyle=color;
ctx.fillRect(upperLeftCornerX,upperLeftCornerY,width,height);
ctx.restore();
var Barchart = function(options){
this.options = options;
this.canvas = options.canvas;
this.ctx = this.canvas.getContext("2d");
this.colors = options.colors;
this.draw = function(){
var maxValue = 0;
for (var categ in this.options.data){
maxValue = Math.max(maxValue,this.options.data[categ]);
var canvasActualHeight = this.canvas.height - this.options.padding * 2;
var canvasActualWidth = this.canvas.width - this.options.padding * 2;
//drawing the grid lines
var gridValue = 0;
while (gridValue <= maxValue){
var gridY = canvasActualHeight * (1 - gridValue/maxValue) + this.options.padding;
drawLine(
this.ctx,
0,
gridY,
this.canvas.width,
gridY,
this.options.gridColor
//writing grid markers
this.ctx.save();
this.ctx.fillStyle = this.options.gridColor;
this.ctx.font = "bold 10px Arial";
this.ctx.fillText(gridValue, 10,gridY - 2);
this.ctx.restore();
gridValue+=this.options.gridScale;
//drawing the bars
var barIndex = 0;
var numberOfBars = Object.keys(this.options.data).length;
var barSize = (canvasActualWidth)/numberOfBars;
for (categ in this.options.data){
var val = this.options.data[categ];
var barHeight = Math.round( canvasActualHeight * val/maxValue) ;
drawBar(
this.ctx,
this.options.padding + barIndex * barSize,
this.canvas.height - barHeight - this.options.padding,
barSize,
barHeight,
this.colors[barIndex%this.colors.length]
barIndex++;
var myBarchart = new Barchart(
canvas:myCanvas,
padding:10,
gridScale:5,
gridColor:"#eeeeee",
data:myVinyls,
colors:["#a55ca5","#67b6c7", "#bccd7a","#eb9743"]
myBarchart.draw();
