You can install directly from Arduino Library Manager
https://www.ardu-badge.com/EthernetWebServer
From v1.0.2+, the library supports many more Arduino boards (Atmel AVR-s, Atmel SAM3X8E ARM Cortex-M3, STM32F series, ESP8266, Intel ARC32(Genuino101), Nordic nRF51(RFduino), Teensy boards, Realtek Ameba(RTL8195A,RTL8710)) using Wiznet W5x00 or ENC28J60 EThernet shields by using UIPEthernet library [url](https://github.com/UIPEthernet/UIPEthernet[/url]) library besides standard Ethernet library(https://www.arduino.cc/en/Reference/Ethernet).
This is simple yet complete WebServer library for `AVR, Teensy,SAM, STM32F, Intel, etc.` boards running Ethernet shields. The functions are similar and compatible to ESP8266/ESP32 WebServer libraries to make life much easier to port sketches from ESP8266/ESP32.
The library supports
1. HTTP Server and Client
2. HTTP GET and POST requests, provides argument parsing, handles one client at a time.
Library is based on and modified from:
1. Ivan Grokhotkov's ESP8266WebServer (https://github.com/esp8266/Arduino/tree/master/libraries/ESP8266WebServer)
The EthernetWebServer class found in EthernetWebServer.h header, is a simple web server that knows how to handle HTTP requests such as GET and POST and can only support one simultaneous client.
Sample Code
#include <SPI.h>
// Use true for ENC28J60 and UIPEthernet library (https://github.com/UIPEthernet/UIPEthernet)
// Use false for W5x00 and Ethernetx library (https://www.arduino.cc/en/Reference/Ethernet)
#define USE_UIP_ETHERNET true
#include <EthernetWebServer.h>
#ifdef CORE_TEENSY
// For Teensy 4.0
#if defined(__IMXRT1062__)
#define BOARD_TYPE "TEENSY 4.0"
#elif ( defined(__MKL26Z64__) || defined(ARDUINO_ARCH_AVR) )
#define BOARD_TYPE "TEENSY LC or 2.0"
#else
#define BOARD_TYPE "TEENSY 3.X"
#endif
#else
// For Mega
#define BOARD_TYPE "AVR Mega"
#endif
// Enter a MAC address and IP address for your controller below.
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
// Select the IP address according to your local network
IPAddress ip(192, 168, 2, 100);
EthernetWebServer server(80);
const int led = 13;
void handleRoot()
server.send(200, "text/plain", "Hello from EthernetWebServer");
void handleNotFound()
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++)
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
digitalWrite(led, 0);
void setup(void)
// Open serial communications and wait for port to open:
delay(1000);
Serial.println("\nStarting HelloServer on " + String(BOARD_TYPE));
// start the ethernet connection and the server:
Ethernet.begin(mac, ip);
server.on("/", handleRoot);
server.on("/inline", [](){
server.send(200, "text/plain", "This works as well");
server.onNotFound(handleNotFound);
server.begin();
Serial.print(F("HTTP EthernetWebServer is @ IP : "));
Serial.println(Ethernet.localIP());
void loop(void)
server.handleClient();
The following are debug terminal output and screen shot when running example AdvancedWebServer (https://github.com/khoih-prog/EthernetWebServer/tree/master/examples/AdvancedWebServer) on Teensy 4.0
