How To Install Using Arduino Library Manager
This library is a Light Weight Credentials / WiFi Manager for WiFiNINA modules/shields, specially designed to support AVR Mega, STM32, Teensy, SAM DUE, SAMD, etc. boards running WiFiNINA modules/shields, with smaller memory (64+K bytes)
You can also specify static AP and STA IP. Use much less memory compared to full-fledge WiFiManager. Credentials are saved in EEPROM, FlashStorage or DueFlashStorage.
You can use this library when your boards have more than 32K bytes of memory, for example Mega1280, Mega2560.
The web configuration portal, served from the WiFiNINA modules/shields is operating as an access point (AP) with configurable static IP address or use default IP Address of 192.168.4.1
Sample Code
/* Comment this out to disable prints and save space */
#define DEBUG_WIFI_WEBSERVER_PORT Serial
#define WIFININA_DEBUG_OUTPUT Serial
#define WIFININA_DEBUG true
#if ( defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_SAMD_MKRWIFI1010) \
|| defined(ARDUINO_SAMD_NANO_33_IOT) || defined(ARDUINO_SAMD_MKRFox1200) || defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) \
|| defined(ARDUINO_SAMD_MKRGSM1400) || defined(ARDUINO_SAMD_MKRNB1500) || defined(ARDUINO_SAMD_MKRVIDOR4000) || defined(__SAMD21G18A__) \
|| defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS) || defined(__SAMD21E18A__) /*|| defined(__SAMD51__) || defined(__SAMD51J20A__) || defined(__SAMD51J19A__) \
|| defined(__SAMD51G19A__)*/ )
#if defined(WIFININA_USE_SAMD)
#undef WIFININA_USE_SAMD
#endif
#define WIFININA_USE_SAMD true
#else
#error This code is intended to run only on the SAMD boards ! Please check your Tools->Board setting.
#endif
#if defined(ARDUINO_SAMD_ZERO)
#define BOARD_TYPE "SAMD Zero"
#elif defined(ARDUINO_SAMD_MKR1000)
#define BOARD_TYPE "SAMD MKR1000"
#elif defined(ARDUINO_SAMD_MKRWIFI1010)
#define BOARD_TYPE "SAMD MKRWIFI1010"
#elif defined(ARDUINO_SAMD_NANO_33_IOT)
#define BOARD_TYPE "SAMD NANO_33_IOT"
#elif defined(ARDUINO_SAMD_MKRFox1200)
#define BOARD_TYPE "SAMD MKRFox1200"
#elif ( defined(ARDUINO_SAMD_MKRWAN1300) || defined(ARDUINO_SAMD_MKRWAN1310) )
#define BOARD_TYPE "SAMD MKRWAN13X0"
#elif defined(ARDUINO_SAMD_MKRGSM1400)
#define BOARD_TYPE "SAMD MKRGSM1400"
#elif defined(ARDUINO_SAMD_MKRNB1500)
#define BOARD_TYPE "SAMD MKRNB1500"
#elif defined(ARDUINO_SAMD_MKRVIDOR4000)
#define BOARD_TYPE "SAMD MKRVIDOR4000"
#elif defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS)
#define BOARD_TYPE "SAMD ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS"
#elif defined(ADAFRUIT_ITSYBITSY_M4_EXPRESS)
#define BOARD_TYPE "SAMD ADAFRUIT_ITSYBITSY_M4_EXPRESS"
#elif ( defined(__SAMD21G18A__) || (__SAM3X8E__) || (__CPU_ARC__) || defined(__SAMD21E18A__) || defined(__SAMD51__) || defined(__SAMD51J20A__) || defined(__SAMD51J19A__) \
|| defined(__SAMD51G19A__) )
#define BOARD_TYPE "SAMD Board"
#else
#define BOARD_TYPE "SAMD Unknown"
#endif
#endif
// Start location in EEPROM to store config data. Default 0
// Config data Size currently is 128 bytes)
#define EEPROM_START 0
#include <WiFiManager_NINA_Lite_SAMD.h>
#define MAX_BLYNK_SERVER_LEN 34
#define MAX_BLYNK_TOKEN_LEN 34
char Blynk_Server1 [MAX_BLYNK_SERVER_LEN] = "";
char Blynk_Token1 [MAX_BLYNK_TOKEN_LEN] = "";
char Blynk_Server2 [MAX_BLYNK_SERVER_LEN] = "";
char Blynk_Token2 [MAX_BLYNK_TOKEN_LEN] = "";
#define MAX_BLYNK_PORT_LEN 6
char Blynk_Port [MAX_BLYNK_PORT_LEN] = "";
#define MAX_MQTT_SERVER_LEN 34
char MQTT_Server [MAX_MQTT_SERVER_LEN] = "";
MenuItem myMenuItems [] =
{ "sv1", "Blynk Server1", Blynk_Server1, MAX_BLYNK_SERVER_LEN },
{ "tk1", "Token1", Blynk_Token1, MAX_BLYNK_TOKEN_LEN },
{ "sv2", "Blynk Server2", Blynk_Server2, MAX_BLYNK_SERVER_LEN },
{ "tk2", "Token2", Blynk_Token2, MAX_BLYNK_TOKEN_LEN },
{ "pt", "Port", Blynk_Port, MAX_BLYNK_PORT_LEN },
{ "mq", "MQTT Server", MQTT_Server, MAX_MQTT_SERVER_LEN },
uint16_t NUM_MENU_ITEMS = sizeof(myMenuItems) / sizeof(MenuItem); //MenuItemSize;
void heartBeatPrint(void)
static int num = 1;
if (WiFi.status() == WL_CONNECTED)
Serial.print("H"); // H means connected to WiFi
Serial.print("F"); // F means not connected to WiFi
if (num == 80)
num = 1;
else if (num++ % 10 == 0)
Serial.print(" ");
void check_status()
static unsigned long checkstatus_timeout = 0;
//KH
#define HEARTBEAT_INTERVAL 600000L
// Print hearbeat every HEARTBEAT_INTERVAL (600) seconds.
if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
heartBeatPrint();
checkstatus_timeout = millis() + HEARTBEAT_INTERVAL;
WiFiManager_NINA_Lite* WiFiManager_NINA;
void setup()
// Debug console
while (!Serial);
Serial.println("\nStart SAMD_WiFiNINA on " + String(BOARD_TYPE));
WiFiManager_NINA = new WiFiManager_NINA_Lite();
// Optional to change default AP IP(192.168.4.1) and channel(10)
//WiFiManager_NINA->setConfigPortalIP(IPAddress(192, 168, 120, 1));
//WiFiManager_NINA->setConfigPortalChannel(1);
WiFiManager_NINA->begin();
void displayCredentials(void)
Serial.println("Your stored Credentials :");
for (int i = 0; i < NUM_MENU_ITEMS; i++)
Serial.println(String(myMenuItems[i].displayName) + " = " + myMenuItems[i].pdata);
void loop()
WiFiManager_NINA->run();
static bool displayedCredentials = false;
if (!displayedCredentials)
if (!strlen(myMenuItems[i].pdata))
break;
if ( i == (NUM_MENU_ITEMS - 1) )
displayedCredentials = true;
displayCredentials();
check_status();
This is the terminal output when running SAMD_WiFiNINA example on example on Nano-33 IoT:
1. Open Config Portal
Start SAMD_WiFiNINA on SAMD NANO_33_IOT
*NN: CrCCsum=6217,CrRCsum=825255525
*NN: CCSum=1983,RCSum=1752461166
*NN: InitEEPROM,sz=1080,Datasz=264
*NN: pdata=blank,len=34
*NN: pdata=blank,len=6
*NN: CrCCSum=3120
*NN: b:OpenPortal
*NN: SSID=WIFININA_E50AB22C,PW=MyWIFININA_E50AB22C
*NN: IP=192.168.4.1,CH=1
Blynk Server1 = blank
Token1 = blank
Blynk Server2 = blank
Token2 = blank
Port = blank
MQTT Server = blank
FFF
2. Got valid Credential from Config Portal, then connected to WiFi
*NN: CrCCSum=7558,CrRCSum=7558
*NN: CCSum=2104,RCSum=2104
*NN: Hdr=WIFININA,SSID=HueNet1,PW=****
*NN: i=0,id=sv1,data=blynk1.duckdns.org
*NN: i=1,id=tk1,data=your-token1
*NN: i=2,id=sv2,data=blynk2.duckdns.org
*NN: i=3,id=tk2,data=your-token2
*NN: i=4,id=pt,data=8080
*NN: i=5,id=mq,data=mqtt.duckdns.org
*NN: con2WF:start
*NN: con2WF:spentMsec=0
*NN: Con2:HueNet1
*NN: IP=192.168.2.139
*NN: WOK
*NN: con2WF:OK
*NN: b:WOK
Blynk Server1 = blynk1.duckdns.org
Token1 = your-token1
Blynk Server2 = blynk2.duckdns.org
Token2 = your-token2
Port = 8080
MQTT Server = mqtt.duckdns.org
HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH
And the Config Portal screens:
1.Main Screen
2. Input Credentials:
3. After pressing Save button
