Connected to MIWIFI_2G_PXN5
ssl_handshake_status: -256
Traceback (most recent call last):
File "main.py", line 19, in <module>
File "urequests.py", line 149, in get
File "urequests.py", line 93, in request
OSError: [Errno 5] EIO
-- after looking in some forums, I found some people referring to the OSE error as caused by memory issues. Given that the program works and gets hard resetted properly after the selected amount of cycles, I can't see why it would be caused by that. About the handshake part, all I've found is that it might be due to time/dates settings differences between my board and router, which doesn't really help either...
If someone could point me to a forum thread with a similar error solved, I would be elated. Thanks!
btw the board is an esp01 + relay module from aliexpress with a wire soldered to pin 4.
import json,network,sys
import urequests as ureq
from machine import Pin,reset
from time import sleep
cycles = 0 # For reset purposes
with open('wlan_set.json') as c: # Load network config as a dict
wlan_set = json.load(c)
sta_if = network.WLAN(network.STA_IF)
sta_if.active(True)
sta_if.connect(wlan_set['ssid'], wlan_set['pass']) # Connect to saved AP
while not sta_if.isconnected(): # Wait until connection is established
pass
print('\n\n Connected to {}'.format(wlan_set['ssid']))
for cycles in range(10):
ts_data = ureq.get('https://api.thingspeak.com/channels/971598/fields/1.json?api_key=CU5423HHCJIR5X91&results=2') #Requests API data
if not ts_data.status_code == 200: # Checks status
print('Cant read web')
dic_data = ts_data.json() # Convert data from json to python
signal = dic_data['feeds'][-1]['field1'] # Nav to the value we want
pin2 = Pin(4, Pin.OUT) # Control GPIO based on value
print(signal)
if signal == '1': # Activate the relay for 1 sec
pin2.on()
sleep(1)
pin2.off()
sleep(15)
ureq.get('https://api.thingspeak.com/update?api_key=295ZUMME6PC3859V&field1=0') # Disables the signal
sleep(5)
reset()
[img]
https://gyazo.com/6b9a706dc7a0ae4c1fc52f0750f586e9
[/img]
