What I want to do is to have an ESP8266 send sensor data to a computer.
Now the ESP can run a web-server which sends javascript code to the webpage and that is that.
That works and is standard procedure.
But that is not what I want.
I want a webpage with some Javascript that adresses an ESP8266 and gets data from it.
That way I can get data from multiple ESP's.
I found some Json webserver code:
#include <ESP8266WebServer.h>
ESP8266WebServer server(80);
const char* ssid = "ROUTERNAME";
const char* password = "PASSWORD";
const char * swaggerJSON = "Swagger JSON API specification";
const char * swaggerUI = "Swagger UI HTML code";
const char * answer = "[{\"value\":\"10.5\",\"timestamp\":\"22/10/2017 10:10\"},{\"value\":\"11.0\",\"timestamp\":\"22/10/2017 10:20\"}]";
WiFi.begin(ssid, password); //Connect to the WiFi network
while (WiFi.status() != WL_CONNECTED) { //Wait for connection
Serial.println("Waiting to connect...");
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //Print the local IP
server.on("/temperature", handleTemperature);
server.on("/swagger.json", handleSwaggerJson);
server.on("/swaggerUI", handleSwaggerUI);
server.begin(); //Start the server
Serial.println("Server listening");
server.handleClient(); //Handling of incoming requests
void handleTemperature() {
server.send(200, "application/json", answer);
void handleSwaggerJson() {
server.send(200, "application/json", swaggerJSON);
void handleSwaggerUI() {
server.send(200, "text/html", swaggerUI);
}Upload this code to an ESP8266 and then wait till it resets. Then open a browser window on your computer and enter:
XXX.XXX.XXX.XXX/temperature
and you will get the JSON code back with the value and timestamp. So this is ok.
Now I want a webpage with some Javascript code that gets that value and displays it in the console
or makes a variable from itr or whatever.
Here is my attempt:
<!DOCTYPE html>
<html>
<body>
<h2>Button test with GET to ESP8266</h2>
<button onclick="putLampOn()">Lamp ON</button>
<br>
<br>
<p>================================================</p>
<script>
function putLampOn() {
var xhttp = new XMLHttpRequest();
xhttp.open("GET", "HTTP://192.168.1.80/temperature", true);
xhttp.send();
xhttp.onreadystatechange = function() {
if (this.readyState == 4) {
// Typical action to be performed when the document is ready:
alert( xhttp.responseText);
alert(JSON.stringify(this.responseText));
alert("testje ", JSON.stringify(this.responseText));
</script>
</body>
</html>
I can not get this to work.
The idea is that I can use this with multiple GET commands to multiple ESP's
and then make a nice looking webpage that displays all kinds off values for an
home automation system.
Another command that Javascript uses is Fetch.
<!DOCTYPE html>
<html>
<body>
<h2>Button test with GET</h2>
<br>
<br>
<script>
fetch("HTTP://192.168.1.80/temperature")
.then(response => response.json())
.then(data => {alert('Success:', data[0])});
</script>
</body>
</html>Also not working.
is there a Javascript expert here who can give me the right code to get the vaule out of the ESP8266.
Luc
