https://electronics.stackexchange.com/questions/332668/attiny13a-capacitive-power-supply
First I plugged in power supply everything is okay but after my ESP8266-01 boot and connect to Wi-Fi its current is reduced and as a result, residual current generated by power supply passes through the zener diode. It makes the zener diode so hot that it cannot be touched. after a while zener diode is burned and overvoltage damaged my ESP8266-01. I am looking for a solution for this problem...
Because of this problem I burned 9 number ESP8266-01
