Page 2 of 2
Re: Problem driving transistors from ESP-01
PostPosted: Mon May 08, 2023 6:45 am
by revan08
Driving transistors from an ESP-01 can be a challenging task, as the ESP-01 module has limited GPIO pins and current output capabilities. Here are some potential solutions to consider:
Use a transistor driver IC: A transistor driver IC, such as the ULN2003, can be used to drive multiple transistors from a single GPIO pin. These ICs have built-in protection diodes and can handle high currents, making them a good option for driving larger loads.
Use a transistor array: A transistor array, such as the ULN2803, can be used to drive multiple transistors from a single GPIO pin. These arrays are similar to transistor driver ICs, but they have more channels and are designed to drive high-current loads.
Use a MOSFET instead of a transistor: MOSFETs have a lower gate-to-source voltage and higher current-handling capabilities than transistors, which makes them a good option for driving high-current loads. However, they may require additional circuitry, such as a gate driver, to ensure proper operation.
Use a relay instead of a transistor: If you need to switch high-voltage or high-current loads, a relay may be a better option than a transistor. Relays can be controlled using a GPIO pin and require minimal additional circuitry.
It's worth noting that the specific solution will depend on the requirements of your project and the components available to you. If you are unsure about how to proceed, it may be helpful to consult with an experienced electronics engineer or technician.
PostPosted: Fri May 12, 2023 3:00 am
by esp8266_dude
revan08: What you wrote is misleading, especially for beginners.
revan08 wrote:Driving transistors from an ESP-01 can be a challenging task, as the ESP-01 module has limited GPIO pins and current output capabilities.
Limited output current may by limiting factor when driving loads directly. Even a ordinary LEDs.
But when you control the transistor, you control their base. Base may by controlled using small currents. That's what transistors are used for: small control current, to drive high current loads. So transistors are pretty easy to drive from GPIOs.
revan08 wrote:Use a transistor driver IC: A transistor driver IC, such as the ULN2003, can be used to drive multiple transistors from a single GPIO pin. These ICs have built-in protection diodes and can handle high currents, making them a good option for driving larger loads.
You are wrong.
ULN2003 and ULN2803 are basically the same kind of thing.
Both are transistor arrays, and both have 50V 500mA capability.
Also, you cannot control ULN2803 using one GPIO pin. You have to use multiple pins, as for to control ULN2003.
revan08 wrote:Use a relay instead of a transistor: If you need to switch high-voltage or high-current loads, a relay may be a better option than a transistor. Relays can be controlled using a GPIO pin and require minimal additional circuitry.
No no no .....
Relay is not a better replacement for transistor.
Driving relays (relay coil) directly from GPIO pin of any uC, is foolishly.
Voltage spikes will damage GPIO, for sure.
Also, coils require high currents (from ESP GPIOs point of view). Even small relays require tens of miliamps (HF3FF with 12 V coil: 30 mA). If you want to drive coil directly from 3.3V source, you need relay with lower voltage coil. That means even more current demands.
Absolutely no chance to drive relay coil from GPIO pins.
To drive relay, you should use a transistor, as "preamplifier".
So relay cannot be replacement to transistor, if you have to use transistor to drive this relay anyway.
I wonder if what you wrote is human text at all.
Because it sounds like AI gibberish (whet AI has nothing left to say and start confabulates).
