Fatal exception error
PostPosted: Fri Sep 25, 2015 6:06 am
by trendchaster
Hello ,
As I am working on sniffer mode and MQTT. The esp8266 12 shows following error during runtime and it is continuously repeating.Do you know how to resolve this issue. Plz guide me.Thanking you in advance.
System started ...
Hello ESP Module.....
mode : sta(18:fe:34:a2:67:47)
add if0
-> -> Promiscuous mode setup ...
done.
Starting for Sniffing the packets
Management Packet (len=128) Sniffed on Channel 11
Data Packet (len=60) Sniffed on Channel 11
cnt: 1
rdaddr: 33:33:00:01:00:02 tsaddr: 9c:d6:43:d7:9e:a4 bssid: 00:21:00:4c:91:7f addr4: 2b:2b:15:60:84:ea
Fatal exception (28):
epc1=0x4000bf64, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000021, depc=0x00000000
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x40100000, len 30820, room 16
tail 4
chksum 0x15
load 0x3ffe8000, len 876, room 4
tail 8
chksum 0x21
load 0x3ffe8370, len 5172, room 0
tail 4
chksum 0xaa
csum 0xaa
rS
load ...
System started ...
add if0
done.
cnt: 1
rdaddr: ff:ff:ff:ff:ff:ff tsaddr: 9c:d6:43:d7:9e:a4 bssid: f8:2f:a8:ce:43:7b addr4: 2b:2b:17:60:00:00
epc1=0x4000bf64, epc2=0x00000000, epc3=0x00000000, excvaddr=0x0000002f, depc=0x00000000
wdt reset
tail 4
chksum 0x15
tail 8
chksum 0x21
tail 4
chksum 0xaa
csum 0xaa
rS
load ...
System started ...
add if0
done.
cnt: 1
rdaddr: 14:2d:27:da:8d:ff tsaddr: 9c:d6:43:d7:9e:a4 bssid: 9c:d6:43:d7:9e:a4 addr4: 00:00:d2:4b:00:20
epc1=0x4000bf70, epc2=0x00000000, epc3=0x00000000, excvaddr=0x000000d4, depc=0x00000000
wdt reset
tail 4
chksum 0x15
tail 8
chksum 0x21
tail 4
chksum 0xaa
csum 0xaa
rS
load ...
System started ...
add if0
done.
cnt: 1
rdaddr: 14:2d:27:da:8d:ff tsaddr: 9c:d6:43:d7:9e:a4 bssid: 9c:d6:43:d7:9e:a4 addr4: 00:00:7a:4c:00:20
wdt reset
tail 4
chksum 0x15
tail 8
chksum 0x21
tail 4
chksum 0xaa
csum 0xaa
rS
load ...
System started ...
add if0
done.
cnt: 1
rdaddr: 14:2d:27:da:8d:ff tsaddr: 9c:d6:43:d7:9e:a4 bssid: 9c:d6:43:d7:9e:a4 addr4: 00:00:f8:4c:00:20
wdt reset
Re: Fatal exception error
PostPosted: Fri Sep 25, 2015 6:40 am
by Barnabybear
Hi, this code give an insight to some of the fault codes. Extract below:
Code: Select allenum rst_reason {
   REASON_DEFAULT_RST      = 0,
   REASON_WDT_RST         = 1,
   REASON_EXCEPTION_RST   = 2,
   REASON_SOFT_WDT_RST      = 3,
   REASON_SOFT_RESTART    = 4,
   REASON_DEEP_SLEEP_AWAKE   = 5,
   REASON_EXT_SYS_RST      = 6
Whilst I can't offer you a reason it looks like a soft restart.
