By bengrech
#44925 Would like to use an ESP-12E as a solar data logger for my solar inverter. The inverter has a serial port DB9 which outputs statistics every 10 seconds. Would like to connect ESP-12E to read these statistics and output them to thingspeak.com
What additional hardware components, if any, are required to be able to connect the ESP-12E to DB9 serial port?
By martinayotte
#44957 BTW, it is even worst : real RS232 signal is swinging between around -7V and +7V, inverted compared to TTL side, -7V is HIGH and +7V is LOW.
You need to use some interface chip such as MAX232, which built the +-7V out from 5V using internal charge pumps.
