I'm trying this :
#include <OneWire.h>
const char* ssid = "ssid"; // Your ssid
const char* password = "password"; // Your Password
OneWire ds(2); // on pin 2 (a 4.7K resistor is necessary)
WiFiServer server(80);
delay(10);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for ( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
break;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
break;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
break;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
} else {
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.print("<p style='text-align: center;'> </p>");
client.print("<p style='text-align: center;'><span style='font-size: x-large;'><strong>ESP8266 and DS18B20 Temperature Sensor Server</strong></span></p>");
client.print("<p style='text-align: center;'><span style='font-size: x-large;'><strong>www.elec-cafe.com</strong></span></p>");
client.print("<p style='text-align: center;'><span style='color: #0000ff;'><strong style='font-size: large;'>Temperature = ");
client.println(celsius);
client.print("</strong></span><h style='text-align: center;'><span style='color: #0000ff;'><strong style='font-size: large;'><sup>o</sup>C</strong></span></h></p>");
client.print("<p style='text-align: center;'> ");
client.print("</p>");
client.println("</html>");
delay(5000);
}But each time I compile I have :
Arduino : 1.6.5 (Windows 8.1), Carte : "Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
Les options de compilation ont été modifiées, tout sera recompilé
In file included from DS18B20_IOT_ESP8266.ino.ino:2:0:
C:\Users\Philippe\OneDrive\Arduino\libraries\OneWire/OneWire.h:108:2: error: #error "Please define I/O register types here"
C:\Users\Philippe\OneDrive\Arduino\libraries\OneWire/OneWire.h:115:5: error: 'IO_REG_TYPE' does not name a type
IO_REG_TYPE bitmask;
C:\Users\Philippe\OneDrive\Arduino\libraries\OneWire/OneWire.h:116:14: error: 'IO_REG_TYPE' does not name a type
volatile IO_REG_TYPE *baseReg;
Erreur lors de la compilation.
Any help please ?... I don't understand ...
