The current is measured using a multimeter at 200mA setting between VCC and 3V3 from the USB-converter.
The following code is used in Arduino:
#define DEEP_SLEEP_TIME 5 // seconds
// === main ==========================================================================
// serial port
while(!Serial); // time to get serial running
Serial.println("Powered on");
delay (2000); // around 70mA at this point
Serial.println("Going into deep sleep mode!");
delay(100);
Serial.end();
ESP.deepSleep(DEEP_SLEEP_TIME * 1e6);
delay(100);
In previous tests, I also had WiFi enabled and considered commands like:
WiFi.config(staticIP, gateway, subnet);
WiFi.persistent( false );
WiFi.mode( WIFI_STA );
WiFi.disconnect(true);
WiFi.mode( WIFI_OFF );
wifi_set_sleep_type(MODEM_SLEEP_T); // LIGHT_SLEEP_T
WiFi.forceSleepBegin();
ESP.deepSleep(DEEP_SLEEP_TIME * 1e6); // also WAKE_RF_DISABLED as 2nd parameter
What is wrong here?
