I already used different sketches on my lolin esp8266 D1 mini pro when suddenly it has become impossible.
Environment : I have same essor message using IDE or Arduino Create web app, before and after fully reinstall. Board is detected on /dev port but impossible to upload. I tried to change data cable.
You can see the error message
Is the board bricked ?
Any idea ?
Thanks everybody
runtime.tools.serial-discovery.path=/home/builder/.arduino15/packages/builtin/tools/serial-discovery/1.1.0 -libraries /tmp/533186290/custom -libraries /tmp/533186290/pinned /tmp/533186290/Blink
Sketch uses 258580 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26696 bytes (32%) of dynamic memory, leaving 55224 bytes for local variables. Maximum is 81920 bytes.
Upload started
Programming with: Serial
Flashing with command:/Users/thomas/.arduino-create/esp8266/esptool/2.5.0-3-20ed2b9/esptool -vv -cd nodemcu -cb 921600 -cp /dev/cu.usbserial-1420 -ca 0x00000 -cf /var/folders/8t/bfs2gtl52wj78bxgtl5f51pm0000gn/T/arduino-create-agent394983170/Blink.bin
esptool v0.4.13-1-gf80ae31 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 921600
setting port from /dev/tty.usbserial to /dev/cu.usbserial-1420
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
opening port /dev/cu.usbserial-1420 at 921600
tcgetattr
warning: serialport_set_baudrate: baud rate 921600 may not work
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
trying to connect
espcomm_send_command: receiving 2 bytes of data
Uploading 262720 bytes from /var/folders/8t/bfs2gtl52wj78bxgtl5f51pm0000gn/T/arduino-create-agent394983170/Blink.bin to flash at 0x00000000
erasing flash
size: 040240 address: 000000
first_sector_index: 0
total_sector_count: 65
head_sector_count: 16
adjusted_sector_count: 49
erase_size: 031000
setting timeout 15000
setting timeout 1000
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
closing bootloader
error: espcomm_upload_mem failed
