(base) PS C:\development\python> esptool --port com3 --baud 9600 write_flash --flash_size detect --flash_mode dio -z 0x0000 esp8266-20210902-v1.17.bin
esptool.py v3.2
Serial port com3
Connecting...
Device PID identification is only supported on COM and /dev/ serial ports.
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting...
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 44:17:93:0d:50:04
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00000000 to 0x0009afff...
Flash params set to 0x0240
Compressed 633688 bytes to 416263...
Writing at 0x00000000... (3 %)Traceback (most recent call last):
File "c:\users\billa\anaconda3\lib\runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "c:\users\billa\anaconda3\lib\runpy.py", line 85, in _run_code
exec(code, run_globals)
File "C:\Users\billa\Anaconda3\Scripts\esptool.exe\__main__.py", line 7, in <module>
File "c:\users\billa\anaconda3\lib\site-packages\esptool.py", line 5136, in _main
main()
File "c:\users\billa\anaconda3\lib\site-packages\esptool.py", line 4602, in main
operation_func(esp, args)
File "c:\users\billa\anaconda3\lib\site-packages\esptool.py", line 3873, in write_flash
esp.flash_defl_block(block, seq, timeout=timeout)
File "c:\users\billa\anaconda3\lib\site-packages\esptool.py", line 154, in inner
return func(*args, **kwargs)
File "c:\users\billa\anaconda3\lib\site-packages\esptool.py", line 919, in flash_defl_block
self.ESP_FLASH_DEFL_DATA, struct.pack('<IIII', len(data), seq, 0, 0) + data, self.checksum(data), timeout=timeout)
File "c:\users\billa\anaconda3\lib\site-packages\esptool.py", line 495, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "c:\users\billa\anaconda3\lib\site-packages\esptool.py", line 458, in command
self.write(pkt)
File "c:\users\billa\anaconda3\lib\site-packages\esptool.py", line 421, in write
self._port.write(buf)
File "c:\users\billa\anaconda3\lib\site-packages\serial\serialwin32.py", line 323, in write
raise writeTimeoutError
serial.serialutil.SerialTimeoutException: Write timeout
(base) PS C:\development\python> esptool --port com3 --baud 9600 erase_flash
esptool.py v3.2
Serial port com3
Connecting...
Connecting...
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 44:17:93:0e:3f:ce
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 4.7s
Hard resetting via RTS pin...
esptool.py v3.2
Serial port com3
Connecting...
Connecting...
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
main()
self.write(pkt)
I have re-downloaded the firmware bin file just incase it had become corrupt somehow. I also attempted the same process on three different esp8266nodeMCU boards, and a RPI Pico. But I get the same result. I have also tried rebooting windows, switching usb cables, and trippel verified the com port is correct, and working OK.
I also ran esptool with the --trace option and pipped it to a file. Nothing in the file jumps out at me as a clue.
Thanks,
Bill
