By RichardS
#47313 How are the monitoring the battery voltage? I expect some sort of voltage divider so the input does not exceed 1.0V
I expect there is an internal reference of 1.0V? Does anyone know for certain how this works?
RichardS
By lorneb
#48025 Hi great idea to keep the data in RTC Ram,
I have some questions,
From what I've read the radio needs to powered up in order to use the ESP.getVcc() function, see: https://www.bountysource.com/issues/261 ... act-values
I noticed this because the values of the getVcc() varied greatly between when the detection was made ( wifi in sleep ) and when the email was about to be sent (wifi awake)
Has anyone else seen this? (I'm using nodeMCU 0.9 and 1.0 board types
2nd up, the line of code: { if (ESP.getVcc() < BATT_WARNING_VOLTAGE)
if ESP.getVcc() returns an Int representing Mv, then how is this ever going to be less than the #Define value you have of 2.X ?
By torntrousers
#48035
lorneb wrote:From what I've read the radio needs to powered up in order to use the ESP.getVcc() function, see: https://www.bountysource.com/issues/261 ... act-values
Worth trying with the latest code as that has fixed this for me. See: https://github.com/esp8266/Arduino/issues/1961
