i have done my own PCB which controls normal DC 12V RGB LED strips - with a lot of helps from "martinayotte" Martin and AdrianM in the schematic part - and it's running flawlessly.
now i found that if i want to have a very long strip will pump by the higher Amps and also the cost of Power supply.
i found that there is RGB LED strips in the market which require no Power supply as it runs directly on 220V AC mains. you just need to hock it to controller which have a IR remote.
here is the question.
any body know what is the schematics in that controller and is that can be controlled with ESP8266?
here is the link and image for the same controller in Aliexpress
http://www.aliexpress.com/item/220v-rgb-led-strip-controller-can-connect-50meter-rgb-led-strip/32556641538.html?spm=2114.01010208.3.1.uiHQVi&ws_ab_test=searchweb201556_8,searchweb201602_1_10037_10017_507_10033_10032_401_10040,searchweb201603_9&btsid=2981833f-dd28-4afd-ab19-6489216786c4
