I am trying to send GET request with static ip address from the esp ,
With client.begin everything works fine the esp gets ip from the DHCP table and the GET request to the server works .
When i use the client.config before client.begin the esp connects to WiFi successfully , and i can see the esp connected to router from the router clients table .
Unfortunately client.connect fails and returns 0 ( port 80 )
What can cause this ? i was thinking the port 80 blocked but its not because its works normally w/o the static ip , i also added port forwarding by trying to open the port from the esp to him self maybe i should do some other forwarding ( i think it has nothing to do with port forwarding ) ?
Any one can help please ?
#include <SPI.h>
const char* ssid = "********";
const char* password = "*******";
const char* host = "*****";
IPAddress ip(192, 168, 0, 20);
IPAddress gateway(192,168,1,1); // this is the gateway ip of the router as i see it when login to the router panel
IPAddress subnet(255,255,255,0);
String Statuses[] = { "WL_IDLE_STATUS=0", "WL_NO_SSID_AVAIL=1", "WL_SCAN_COMPLETED=2", "WL_CONNECTED=3", "WL_CONNECT_FAILED=4", "WL_CONNECTION_LOST=5", "WL_DISCONNECTED=6"};
delay(10);
Serial.println(ssid);
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
delay(100);
Serial.println(Statuses[WiFi.status()]);
delay(5000);
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
Serial.println("connection failed error");
Serial.println(client.connect(host, httpPort));
return;
}I have written question on github developer's support :
https://github.com/esp8266/Arduino/issues/2182
Thanks !
