Relay boards for WEMOS D1 R2
Posted: Sun Jul 03, 2016 7:41 am
I have been trying to the Catalex Relay Shield V1.0 (which appears clone of http://www.seeedstudio.com/wiki/Relay_Shield_V2.0) on my WEMOS D1 R2 V 2.1.0.
Seems simple enough, relay shield designed for UNO on an UNO clone. The problem is that when the shield is mounted the WEMOS does not come up. I am only powering from the usb port so I am suspecting I will have to power the board from the battery connector (certainly when I rechecked the schematic) it was apparent there no 5V coming from the USB up to the 5volt pin. Even so, I would have expect that I could not drive the relays but not that the WEMOS would not work.
When I take the shield out all is well. The relay driver inputs are D2, D3, D4 and D5 of the IOL header of the WEMOS, and the ground, 3.3V and 5V pins all are happily placed as well. So, it isn't obvious what the coupling is.
Has anyone else tried a UNO four relay shield on their WEMOS D1 R2?
Cheers,
A
Cheers,
A
