I don't get it... There are lots of boards out there (like the Witty Board) that include a USB to Serial converter, like the CH340G, and additional level converters to shift TTL levels down to 3.3V to talk to the ESP. There are also lots of tutorials that talk about different methods to use your 5V USB to Serial converter with the ESP8266 using level shifting...
But why??
When I got my first ESP8266, the first question I asked myself was, do I really have to use 5V TTL levels in the first place? The answer, obviously to me (but to others??), was NO!
Almost ALL USB to TTL Converters support 3.3V operation, which means, you can just supply them with 3.3V and they will output 3.3V TTL levels.
The CH340G meantions this in the Datasheet:
CH340 supports 5V and 3.3V operation. When using 5V operation, supply 5V to VCC pin, and
decouple the internal 3.3V reference with a capacitor of 4.7-20nF from V3 pin to ground.
When using 3.3V operation, tie V3 pin to VCC pin and supply 3.3V power.
So, why do all people use 5V Vcc from USB and shift levels afterwards, instead of just converting 5V from USB down to 3.3V and use this as Vcc for everything else? No level conversion needed
Since I have a lot 5V TTL converters myself, I just made myself a USB to 3.3V converter:
http://www.thingiverse.com/thing:768406
Works out of the box with all 5V USB TTL converters I have...
So, if you design a new board, just drop that unnecessary level shifting
Hope that was helpful to you
Btw: Tell me when you actually see a board using 3.3V in the first place... I couldn't find one so far.
