My VirtualWire compiling errors.
Has anyone had good results with ESP + 433MHz hardware?
Explore... Chat... Share...
bbx10node wrote:VirtualWire is obsolete and has been superceded by RadioHead. I think the errors are caused by AVR code which does not work on ESP8266. RadioHead appears to support ESP8266 but I am not sure which radios are supported.
I am experimenting with RFM69 radios which are available in 433, 915, and 868 MHz versions. Looks good so far.
