Too many flashes cause module to fail?
Posted: Mon Jan 05, 2015 9:06 am
After 1 month of rigorous developing on my ESP-07 module which involves about average 40-60 times reflashing, my module finally refuses to boot.
The phenomenal is gradually worsening, from at the beginning it fails to boot occupationally, to a prolonged period that it refuses to boot continuously but once booted, it is all right for the whole day even between power cycling, until today it enters a wdt reset loop for an hour, then completely refuses to boot.
All I have now it boot message as
The module draws 200mA at this stage.
I wonder if anyone has observed the same phenomenon. I have ruled out firmware issue since I have tried many versions of firmware all have the same result. I guess the flash chip died (but it writes successfully). Maybe I'll popup the metal can and replace the chip to verify.
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
load 0x40100000, len 29288, room 16
tail 8
chksum 0x49
load 0x3ffe8000, len 1972, room 0
tail 4
chksum 0x26
load 0x3ffe87c0, len 7364, room 4
tail 0
chksum 0xb3
csum 0xb3
