By buchacho
#55112 I tried searching here, but did not find any mention of the new ESP-12S modules. Does anyone know what the difference is from the previous F model besides removing the pads from the bottom edge? The FCC ID indicates it was recently approved.
By lethe
#55115 The layout looks cleaner, but apart from the missing bottom pins, there doesn't seem to be any major difference.
See https://fccid.io/document.php?id=3087389 vs. https://fccid.io/document.php?id=2752712
The new layout is less cramped and only places components at 0° and 90° angles, so I guess the redesign was mostly for assembly reasons (possibly faster/cheaper pick & place, higher yield).
By buchacho
#55142 The holes are gone inside the pads. I wonder if there are any wifi performance improvements.
*edit* They are the same size.
By Barnabybear
#55143 Hi, I always suspected that the pins that are missing on this unit were broken out so the the flash could be accessed directly whilst holding CH_PD low. It looks like no one is programing that way so they have been dropped in favor of a slightly smaller form factor. As stated above the new layout may be faster to produce and looks to have slightly better internal clearance to the sreening can.
