ÿó¡àmX,ÊïGÍaæ0ù«>ìP$#tÿÆe¸&©Ïõæ xìþÿÿ[Vendoúÿÿÿÿÿÿÿÿÿhinkerîÿÿÿÿÿÿÿon:0.9þÿÿÿÿÿÿÿÿÿeady
üüÿÿÿÿÿÿÿµ^erÿÿÿÿÿÿÿÿÿÿong syîÿÿÿÿÿÿÿÿSOR
Ãüÿÿÿÿÿÿÿ=
wroÿÿÿÿÿÿÿÿÿ
ERþÿÿÿÿÿÿÿOr another time it was like this (I think I see version 9.2.4 in there)
¡àí[ªëÇCÅaæª æôÀ¡H2¤ðVùvêouKüæ$yÿÿÿÿÿÿÿodor:ww÷ïÿÿÿÿÿÿ«Kië«ë»ÿÿÿÿÿÿÿ?.9.2.4ýÿÿÿÿÿÿßÿ5)jÒúõÿÿÿÿÿÿÿ¿oróZËÿøìÿÿÿÿÿÿÿK+ÿøüüÿÿÿÿÿì?ÿAny thoughts?
I have scoped the 3.3V rail from the ATX PSU and I see it is getting 3.6V actually. Could that be a problem?
I am using pins 2 and 3 for the software serial on the Arduino connected directly to the 8266 TX and RX.
Here is the sketch code:
#include <SoftwareSerial.h>
SoftwareSerial esp8266(2,3); // make RX Arduino line is pin 2, make TX Arduino line is pin 3.
// This means that you need to connect the TX line from the esp to the Arduino's pin 2
// and the RX line from the esp to the Arduino's pin 3
void setup()
Serial.begin(9600);
Serial.println("Startup");
esp8266.begin(9600); // your esp's baud rate might be different
void loop()
if(esp8266.available()) // check if the esp is sending a message
while(esp8266.available())
// The esp has data so display its output to the serial window
char c = esp8266.read(); // read the next character.
Serial.write(c);
if(Serial.available())
// the following delay is required because otherwise the arduino will read the first letter of the command but not the rest
// In other words without the delay if you use AT+RST, for example, the Arduino will read the letter A send it, then read the rest and send it
// but we want to send everything at the same time.
delay(1000);
String command="";
while(Serial.available()) // read the command character by character
// read one character
command+=(char)Serial.read();
esp8266.println(command); // send the read character to the esp8266
