Page 1 of 2
Temperature Sensor
PostPosted: Tue Sep 16, 2014 10:30 am
by hackrid
Hi,
somewhere i read this thing should have an internal temperature sensor.
Any info on that available beside this piece in the linker file?
Code: Select allPROVIDE ( rom_abs_temp = 0x400060c0 );
Re: Temperature Sensor
PostPosted: Tue Sep 16, 2014 11:51 am
by jonsmirl
I have not seen anything about an internal temp sensor. Their demo boards have this chip on them and support for it is in their IoT SDK
https://www.mems-vision.com/products-se ... /mvh3004d/
PostPosted: Tue Sep 16, 2014 12:01 pm
by hackrid
https://nurdspace.nl/ESP8266#Characteristics
Musst be something integrated as well.
PostPosted: Tue Sep 16, 2014 12:06 pm
by jonsmirl
My experience with built-in temp sensors is that they are fairly useless for reading ambient temperature. What they are useful for is when the chip is in a hostile environment. You can use the on-die temp sensor to watch the die temp. Then if the chip is about to fail from over heating make changes in the system (change a duty cycle, turn on a fan) to keep the chip running.
