By KevinA
#56222 New memory arrived! New memory won't fit :(
The only memory I've found is W25Q80DVSNIG (1MB) from Digikey @$.31 - The 8-SOIC (0.154", 3.90mm Width) is the killer. The 25Q64 and 25Q128 was 8-SOIC (0.209", 5.30mm Width). I found some 25Q16 2MB but they are discontinued or Digikey only sells 3K at minim. Now that I know 8-SOIC comes in two sizes, different voltage levels and different speeds I know what to look for.
By piersfinlayson
#56226 Have the W25Q128FVSIG on order from aliexpress, which should fit (it's the same code as other smaller capacity flash I've ordered before and fits):
https://www.aliexpress.com/item/Free-Shipping-5pcs-lot-W25Q128FVSSIG-W25Q128FVSG-W25Q128FVSIG-W25Q128-WINBOND-SOP-8/32545581440.html?spm=2114.13010608.0.0.pKOPaN
Not arrived yet though so can't guarantee it'll work.
I have successfully upgraded esp-01 and esp-07 to the 4MB (32Mbit) variant of this chip.
By KevinA
#56243
martinayotte wrote:All those Wide-SOIC-8 fits if you bend the pins and solder them carefully.
I purchased a pair of " Magnifying Glasses" https://goo.gl/BxUoXs to do this small work, don't waste your money. The " Magnifying Glasses" work if the object is 10mm from the lens.... Other than that everything is way out of focus. I have one of the old Fluorescent bulb based arm magnifying lamp but wanted something more flexible.
Has anyone tried: https://goo.gl/LpL7ut Headband Headset 2 LED Head Lamp Light ?
My pet rock collection just keeps expanding...
I had to remove and resolder an EMW3165, pin pitch 1mm, that took awhile :o
I just found one that might work: https://goo.gl/xHu3v3 they state the distance:
Magnifications Distance to viewed objects
1.0x 300 ~ 350mm 13 inch
1.5x 240 ~ 260mm
2.0x 215 ~ 235mm
2.5x 205 ~ 225mm
3.0x 160 ~ 180mm
3.5x 135 ~ 145mm
4.0x 125 ~ 135mm 5.3 inch
4.5x 110 ~ 130mm
5.0x 100 ~ 120mm
5.5x 80 ~ 95mm
6.0x 60 ~ 85mm 3.3 inch
