I'm doing some tests with NodeMCU and it is powered by USB computer right? Could I use a mobile charger with micro USB output to power the NodeMCU?
Also use as alternative power, a battery 12v going through a 7805 regulator connected to GND and Vin
Explore... Chat... Share...
