Selfmade relay board tips
Posted: Thu Nov 10, 2016 9:00 am
Hi
I have made my own version of an ESP board which has 2 relays on it to switch on/off. I also can connect a temp sensor (GPIO13) and 2 servos (GPIO12, 14). My voltage source is a 220V->5V AC/DC converter.
I plan to make 2 versions, one with a 220V/5V converter and an additional step down 5V->3.3V converter with 5V relays.
The second version, which I will prefer will be with a 220V -> 3.3V AC/DC converter and 3V relays ( instead of the stepdown converter I simply shorten the 2 pins).
* Are there any optimizations I could make (change pullups/down?, additional capacitors ?).
* Do I have to change to values of the resistors for the transistor base for 5V and 3.3V version. I ask different: Which resistors do I have to change when running at 5V or 3.3V ?
* Are there any potential problems ?
thanks in advance
regards
Erich
thanks in advance
regards
Erich
