By chrissou
#7297 18:26:15Fatal exception (0):
Hi
Running a custom firmware based on SDK 0.9.4 and modified esp-httpd
When I turn off the wifi (whereas the esp was connected), I get :
epc1=0x4024b3a0, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
18:26:17
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x40100000, len 27056, room 16
tail 0
chksum 0xea
load 0x3ffe8000, len 2812, room 8
tail 4
chksum 0x69
load 0x3ffe8b00, len 5904, room 4
tail 12
chksum 0x1d
csum 0x1d
epc1=0x40250580, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
epc1=0x40240880, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
any idea ?
Thx
By managed_prune
#13452 I've just started getting the same thing. It used to boot fine, now I've not managed to get it to boot at all, it always just gives that error. I've reflashed numerous times, using old code that I'm sure works too.
Did either of you figure out the issue?
By chrissou
#13453
Hi
Probably related to hardware issue...
In my case works correctly since I changed the power supply to a better regulated one...
Chris
agree
