My first tests with a Wemos board (D1 mini) seem to indicate that the ESP8266 is not fast enough for this.
Is it possible to sample this quickly with an ESP8266 assuming further optimizations or should I be looking into other, faster chips?
Explore... Chat... Share...
#define GPIO_IN ((volatile uint32_t*) 0x60000318)
uint32_t data;
while(!digitalRead(CLOCK)) { }
// rising edge
data = *GPIO_IN;
// wait for falling edge
while(digitalRead(CLOCK)) {}
}#define CLOCK 0x0010 // GPIO4 bit mask
#define DATA 0x0020 // GPIO5 bit mask
uint32_t data;
while((*GPIO_IN & CLOCK) == 0) { }
// rising edge
data = (*GPIO_IN & DATA);
while((*GPIO_IN & CLOCK) == 1) {}
