I did edit a sketch for Arduino to on / off a relay via local wifi. My Board is a NODEMCU.
E.g. if you type 192.168.1.101/5/1 relay on GPIO 5 on and with 192.168.1.101/5/0 goes OFF. Another, if you call 192.168.1.101/5
you get the state of PIN 5. If you edit at top, you can add others PIN so render sketch many abstract.
My only doubt is that with a model of Relay Module this works very well. 0 == OFF and 1 == ON. With another type, relay is ON at the bootup.
1) I think that I need to add PULL DOWN resistor to my circuit?
2) If I did understand very well, I cannot set the PULL DOWN via software?
This is the module that works as expected:
And module that works "otherwise":
My simple wiring is:
VIN to + (1st module) // VCC (2nd module)
GND to - (1st module) // gnd (2nd module)
GPIO5 to S (1st module) // IN (2nd module)
No transistor, no resistor. Maybe I need a resistor between GND (nodemcu) and GPIO5 (nodemcu) as PULL DOWN?
This is the code:
* This sketch sends data via HTTP GET requests to data.sparkfun.com service.
* You need to get streamId and privateKey at data.sparkfun.com and paste them
* below. Or just customize this script to talk to other HTTP servers.
IPAddress ip(192, 168, 1, 101);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
const char* ssid = "HIC_SUNT_LEONES";
const char* password = "***";
WiFiServer server(80);
delay(10);
Serial.println(ssid);
/* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
would try to act as both a client and an access-point and could cause
network-issues with your other WiFi-devices on your WiFi-network. */
WiFi.mode(WIFI_STA);
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
server.begin();
// add here all pin need to be used
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
int getHowManyOccurence(String url) {
int i = 0;
int occurence = 0;
int string_length = url.length();
for (i=0;i<string_length;i++) {
if (url[i]=='/') {
occurence++;
return occurence;
String getNewGpioStateFromUrl(String url) {
if (url.lastIndexOf("/")!=-1) {
int last_index = url.lastIndexOf("/");
String new_pin_state = url.substring(last_index+1);
return new_pin_state;
} else {
return "";
String getGpioFromUrl(String url) {
String gpio;
int first_index = url.indexOf("/");
if (last_index==first_index) {
gpio = url.substring(1,url.length());
} else {
gpio = url.substring(1,last_index);
Serial.println("------ GETTING GPIO");
Serial.println(gpio);
return gpio;
} else {
Serial.println("LAST INDEX -1");
return "";
String getCleanUrl(String url) {
url.replace("GET ", "");
url.replace(" HTTP/1.1", "");
return url;
String getGpio(String gpio) {
int state;
String return_state;
int pin = atoi (gpio.substring(0,gpio.length()).c_str ());
state = digitalRead(pin);
if (state==HIGH) {
return_state = "1";
} else {
return_state = "0";
return return_state;
void setGpio(String gpio, String state) {
int new_state;
int length_of_string = gpio.length();
int pin = atoi (gpio.substring(0,length_of_string).c_str ());
if (state=="1") {
new_state = HIGH;
} else {
new_state = LOW;
digitalWrite(pin,new_state);
void printJsonAnswer(WiFiClient client, String state) {
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: application/json");
client.println("Access-Control-Allow-Origin: *");
client.println("Connection: close");
client.println("");
String response = "\"" + state + "\"";
client.println(response);
void printPage(WiFiClient client) {
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<body>");
client.println("<h1>");
client.println("Benvenuto in ESP 8266!");
client.println("</h1>");
client.println("</body>");
client.println("</html>");
if (!client) {
return;
Serial.println("new client");
while(!client.available()){
delay(1);
String raw_url = client.readStringUntil('\r');
Serial.println(raw_url);
client.flush();
String url = getCleanUrl(raw_url);
Serial.println("La url chiamata pulita è ");
Serial.println(url);
// Match the request
// it's a get!
String gpio = getGpioFromUrl(url);
if (gpio!="") {
Serial.println("La GPIO è ");
int occurence = getHowManyOccurence(url);
Serial.println("Abbiamo trovato questo numero di slash ");
Serial.println(occurence);
if (occurence==2) {
String new_pin_state = getNewGpioStateFromUrl(url);
if (new_pin_state!="") {
Serial.println("Il nuovo stato richiesto è ");
Serial.println(new_pin_state);
setGpio(gpio,new_pin_state);
String state = getGpio(gpio);
//printPage(client);
printJsonAnswer(client,state);
delay(1);
Serial.println("Client disconnected");
Serial.println("");
Thank you to all
