Page 1 of 2
CPU Heat Problem
PostPosted: Fri Feb 24, 2017 1:58 pm
by Lakshan Fernando
Hi,
I'm using esp-1 inside a switch box and cpu getting extremely hot.
1. Is there any method to dissipate the heat?
2. Would putting it to light sleep help to cool down a bit?
3. What would happen if keep it running as it is in that temperature? (As of now it is running fine for 2+ days. Not sure for long run it will get fried.)
4. Is there anyway to measure the cpu temperature and turn it off for awhile?
Re: CPU Heat Problem
PostPosted: Fri Feb 24, 2017 4:13 pm
by jankop
You've got some fault in the wiring. Under normal conditions, it does not heat anything.
PostPosted: Fri Feb 24, 2017 4:41 pm
by Lakshan Fernando
Hi Jankop,
The power is supplied via a LM1117 and VCC, RST, and CH_PD pins are connected to the 3.3 source.
Also I have connected a 10mf capacitor.
Is this wiring ok?
PostPosted: Sun Feb 26, 2017 6:10 am
by jankop
To make it make sense to talk about it, you would have to specify the whole circuit. Thus, I can only say there something you're wrong.
