Trying to connect a 2.2" TFT display
PostPosted: Tue Apr 11, 2017 6:08 am
by nyl
I am struggling in trying to connect a 11 pin TFT display to the esp8266
I believe I made a mistake and bough a model that is for the raspberry pi.
do I still have a chance to make it work on the esp8266 ?
I have attached a pict of the display
Re: Trying to connect a 2.2" TFT display
PostPosted: Thu Apr 13, 2017 3:05 pm
by grtyvr
Are you programming the ESP8266 in an arduino IDE? If so, then I would try using the adafruit libraries for TFT displays:
Adafruit_GFX Library
Adafruit_ST7735 Library
Then you would just make sure that the pin assignments are correct. When I get home I can check some notes I made on doing this.
PostPosted: Thu Apr 13, 2017 5:13 pm
by nyl
yes I am using the arduino IDE
PostPosted: Thu Apr 13, 2017 7:27 pm
by rudy
Try this one https://github.com/Bodmer/TFT_eSPI
An Arduino IDE compatible graphics and fonts library for ESP8266 processors with a driver for ILI9341, ILI9163, ST7735 and S6D02A1 based TFT displays that support SPI.
