Features are:
- Fits ESP-12 and ESP-07 module
Single-sided self-etchable design
All parts are SMD
Breadboard-style - one row on each side accessible
Vin >4.5V (max. 7V) input possible with 3V3 onboard voltage regulator (with two capacitors 10µF)
Power-indicator LED
(Schottky-) Diode as reverse polarity input protection possible (solder 0 Ohm resistor or just connect the two pads for no protection)
RST, CH_PD, GPIO0 with 4k7 pull-up resistors on board (resistors can be omitted if remote access of those GPIOs is needed)
GPIO15 with 4k7 pull-down (see above)
Tactile switch connected to GPIO0 to get into flash mode
Single post for 3.3V output near voltage regulator
This is the actual revision 1.0 - improved for:
- Antenna part now protruding the PCB (no traces below antenna)
Wider traces
Schottky diode for reverse polarity protection
2x 10µF ceramic caps for input/ output of AMS1117
markbee
