NRF24L01 + SPI
Posted: Wed Jun 14, 2017 3:47 pm
Hi!
With ESP8266 the NRF24L01 scanner not works via SPI bus. There are 2 SPI in ESP. I don't know what is the difference, but I tried all of them. In RF24 library there is a scanner template and it doesn't compile. (Arduino IDE 1.8.3, atest libraries and boards)
There is an other method what Works for me with arduino uno but not with ESP.
I tried many methods to wake the device. It compiled but not Works. When I move the CSN connector, somtimes prints random data but it is not real. So it Works wit Arduino (with SPI.setClockDivider(SPI_CLOCK_DIV4);) but doesn't Works with ESP.
Maybe the clock freq is not OK. I don't know. Please help. Thank you!
I have NodeMCU and Wemos D1 and standalone ESP-12E modules.
#include <SPI.h>
#define CE D2
#define CSN D8 //ss
// Array to hold Channel data
#define CHANNELS 64
int channel[CHANNELS];
// greyscale mapping
int line;
char grey[] = " 123456789";
// nRF24L01P registers we need
#define _NRF24_CONFIG 0x00
#define _NRF24_EN_AA 0x01
#define _NRF24_RF_CH 0x05
#define _NRF24_RF_SETUP 0x06
#define _NRF24_RPD 0x09
// get the value of a nRF24L01p register
byte getRegister(byte r)
byte c;
digitalWrite(CSN,LOW);
c = SPI.transfer(r&0x1F);
c = SPI.transfer(0);
digitalWrite(CSN,HIGH);
return(c);
// set the value of a nRF24L01p register
void setRegister(byte r, byte v)
SPI.transfer((r&0x1F)|0x20);
SPI.transfer(v);
// power up the nRF24L01p chip
void powerUp(void)
setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)|0x02);
delayMicroseconds(130);
// switch nRF24L01p off
void powerDown(void)
setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)&~0x02);
// enable RX
void enable(void)
digitalWrite(CE,HIGH);
// disable RX
void disable(void)
digitalWrite(CE,LOW);
// setup RX-Mode of nRF24L01p
void setRX(void)
setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)|0x01);
enable();
// scanning channels
void scan(void)
disable();
for( int j=0; j<64; j++)
for( int i=0 ; i<CHANNELS ; i++)
// select a new channel
setRegister(_NRF24_RF_CH,(128*i)/CHANNELS);
// switch on RX
setRX();
// wait enough for RX-things to settle
delayMicroseconds(40);
// this is actually the point where the RPD-flag
// is set, when CE goes low
disable();
// read out RPD flag; set to 1 if
// received power > -64dBm
if( getRegister(_NRF24_RPD)>0 ) channel[i]++;
// outputs channel data as a simple grey map
void outputChannels(void)
int norm = 0;
// find the maximal count in channel array
if( channel[i]>norm ) norm = channel[i];
// now output the data
Serial.print('|');
int pos;
// calculate grey value position
if( norm!=0 ) pos = (channel[i]*10)/norm;
else pos = 0;
// boost low values
if( pos==0 && channel[i]>0 ) pos++;
// clamp large values
if( pos>9 ) pos = 9;
// print it out
Serial.print(grey[pos]);
channel[i] = 0;
// indicate overall power
Serial.print("| ");
Serial.println(norm);
// give a visual reference between WLAN-channels and displayed data
void printChannels(void)
// output approximate positions of WLAN-channels
Serial.println("> 1 2 3 4 5 6 7 8 9 10 11 12 13 14 <");
void setup()
Serial.println("Starting...");
// Channel Layout
// 0 1 2 3 4 5 6
// 0123456789012345678901234567890123456789012345678901234567890123
// 1 2 3 4 5 6 7 8 9 10 11 12 13 14 |
Serial.println("Channel Layout");
printChannels();
// Setup SPI
SPI.begin();
SPI.setFrequency(40000000);
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(MSBFIRST);
//SPI.setClockDivider(SPI_CLOCK_DIV4);
//SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0));
// Activate Chip Enable
pinMode(CE,OUTPUT);
disable();
// now start receiver
powerUp();
// switch off Shockburst
setRegister(_NRF24_EN_AA,0x0);
// make sure RF-section is set properly
// - just write default value...
setRegister(_NRF24_RF_SETUP,0x0F);
// reset line counter
line = 0;
void loop()
// do the scan
scan();
yield();
// output the result
outputChannels();
yield();
// output WLAN-channel reference every 12th line
if( line++>12 )
printChannels();
line = 0;
