In MCU world, like arduino, timer (hardware) have max priority in system, then, if MCU is locked inside of any loop, timer go to function without problems.
But in ESP, OS_TIMER don't make this, if MCU is locked inside of any loop, os_timer can't go to a function WITHOUT yield's or delay's.
How can i change os_timer to max priority (if have)? I testing hardware watchdog and need to feed her, even MCU inside of loop without yield.
I know os_timer is based on software, but can change this situation?
Image of testing code.
Hardware watchdog has ~8 seconds to reset MCU, then, I put timer to feed before 8 sec. I put an while to lock MCU inside of loop. Hardware Watchdog DON'T fed with yield or delay, like Software Watchdog.
Loop with yield, os_timer work's and MCU not reset. Because yield processes some task os system I think.
Loop without yield, os_timer doens't work, then HW WDT reset.
OK, OK. After explications, I need to UP task priority of os_timer without put yield in all of 2500 lines.
