Page 1 of 3
ESP-201 review
PostPosted: Sat Feb 07, 2015 4:04 pm
by squix78
Hi forum
Yesterday I received two shiny ESP-201. I ran some tests to figure out the improvement of sensitivity when using the external antenna. IMHO it is quite impressive, not gonna use those on-board antennas anymore if I have the choice;-). I also found a way to put them on a tiny breadboard, mere brut force actually...
You'll finde the whole review here:
http://blog.squix.ch/2015/02/esp8266-esp-201-breakout-board-review.html
Cheers,
Dani
Re: ESP-201 review
PostPosted: Sun Feb 08, 2015 1:01 pm
by quantalume
That's a great writeup, thanks. I ended up unsoldering the serial pins and resoldering them facing up. This way, I can eventually solder the module into a circuit and have the pins available for firmware updates. Now, if someone would just come out with a cheap module which includes a LDO, life would be great!
Re: ESP-201 review
PostPosted: Sun Feb 08, 2015 4:24 pm
by steves
Interesting writeup, thanks.
With the external antenna plugged in, it appears as though the esp transceiver is connected to both antennas at once (in parallel), and therefore seeing 25ohms load instead of the 50ohms that it is designed for.
I wonder if cutting the traces to the internal antenna ( near the top of the U in the photo) would make a noticeable difference?
Cheers,
Re: ESP-201 review
PostPosted: Mon Feb 09, 2015 2:07 am
by lethe
Looking at the photos, I'm not even sure that the PCB antenna is connected. It kinda looks like the 0ohm resistor is meant for antenna selection.
@squix78: could you check using a multimeter, if the PCB antenna is actually connected?
