I have a problem on CIPSTART command: I receive 0,closed and I have not found in documentation so that means.
This happens on second send; in the first send maybe I did not sent the data correctly?
best regards
John Rossati
Explore... Chat... Share...
AT+CIPSTART="TCP","192.168.0.4",3912[Vendor:www.ai-thinker.com Version:0.9.2.4]
ready
Firmware version
AT+GMR
0018000902-AI03Firmware version
AT+GMR
0020000903
compiled @ Dec 15 2014 19:43:31It takes about 20-25 seconds for home assistant c[…]
