- Mon Aug 14, 2017 5:07 pm
#69064
First things first: a good thing you bought a real development board; it makes things much easier when you're new.
- Connect your NodeMCU, make a note of the COM-port number (I'll take COM4 as an example here)
- In PuTTY, create a profile with the following settings:
- Connection type: Serial
- Serial line: [YOUR COMPORT] eg. "COM4" (without the qoutes)
- Speed: 74880 (yes: this is an unusual baud rate, not a typo)
Save this profile as "ESP-COM4-74880" - Open this connection by pressing the "Open" button: you should see a black window
- Now press the RST (= RESET)-button on the NodeMCU, you should see a text similar to this:
Code: Select all ets Jan 8 2013,rst cause:2, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v00000000
~ld If you get messages like "chksum err" (or "csum err"), your previous flash attempt failed and you'll have to reflash your NodeMCU with the correct firmware and settings and return to step 3 above. - When you're getting a message like above (thus NO "csum err" lines), you *should* be able to use the firmware you've flashed.
- Create another profile in PuTTY with the settings:
- Speed: 115200
Save this profile as "ESP-COM4-115200" - Open the connection by pressing the "Open"-button: you should see a black window with a green cursor.
- Now press (without making a typing error!) the letters "AT" (no quotes) followed by [CTRL]+M and [CTRL]+J ([CTRL] is, of course, the CTRL-key on your keyboard)
If you do make an error while typing, don't back space, but perform a [CTRL]-M & [CTRL+J] (you'll get a message saying "ERROR") and try again. - You should be greeted with the message "OK"if the command could be processed
- Try other AT-commands, like the ones in this list.
If you're stuck, please let us know and be as detailed as possible (ie. don't just say: "It doesn't work").
Assumption is the mother of all f*ckups. At least: that's what I'm assuming.
