Yesterday, my first ESP8266 arrived. I was so excited!
I've connected the ESP8266 directly to an USB TTL (http://www.ebay.at/itm/321504039146?ssP ... 1439.l2649) using this wiring:
3.3v => 3.3v
GND => GND
TX => RX
RX => TX
CH_PD => 3.3v
and then i tried the "AT" command and then .. nothing happend
Then i tried to flash different firmwares, a 0.9.5.0 AT Firmware, an older 0.9.2.2 AT Firmware, the nodemcu firmware etc.. For this, i've connected the GPIO 0 to GND as stated in several how-to's. The flashing tool worked without any problems, it could read both mac-addresses and the firmware could be loaded to the module. Of course, i've disconnected the GPIO0 pin from GND.
I have tried different baud rates, different terminal programs (putty, arduino-built-in, ssom32 and even on a linux machine using screen and minicom). One time only i saw the welcome message when booting, but when i tried to reboot the module, nothing happend. Occasionally i saw the ESP-xxx AP in my wlan list and when i connected the RESET pin to GND, the blue light on the module and the "RX" light on the USB TTL was blinking for a very long time. Rarely i could read some data, but it was not human-readable. ( I also tried using different baud rates..)
I have also tried to connect via the Arduino (using a voltage devider for the module's RX pin), but even the example code did not work:
#include <SoftwareSerial.h>
SoftwareSerial dbg(10, 11);
dbg.begin(9600);
dbg.println("hi there!");
pinMode(13, OUTPUT);
Serial.begin(115600);
Serial.println("AT+RST");
delay(1000);
if (Serial.find("ready"))
dbg.println("device ready");
else {
dbg.println("not ready");
delay(2000);
}is my new ESP8266 defect? I'm 100% sure i did not mess up the wiring. I've double and triple checked the wiring before powering the module on
please help, i can't wait to start hacking
