Re: Internal pull-up on reset pin
Posted:
Tue Aug 15, 2017 1:50 pm
by QuickFix
Not as far as I know (it's a hardware reset, not a GPIO), but
maybe our Wiki can give you an anwer?
Posted:
Wed Aug 16, 2017 5:53 am
by btidey
I think you'll find that the RST pin has a weak pull up of the order of 12K. Some modules may also have a capacitor to ground.
The CH/PD enable pin, however, should have an external pull up or be wired to Vd/
Posted:
Wed Aug 16, 2017 12:03 pm
by martinayotte
Never trust Internal PullUps, they are weaker than 12K, probably more around 100K.
See my very old post :
viewtopic.php?f=6&t=4390&p=25390&hilit=antenna+effect#p25390During those old days, even a guy complained that just touching the RES pin with a small camera screwdriver was producing random resets.
Posted:
Wed Aug 16, 2017 12:22 pm
by rudy
Internal pullups on port pins are typically between 50k-100k. They are a convenience and you have to evaluate your needs before you rely on using only them.
