(SOLVED) ESP8266-03 not responding
Posted: Tue Feb 17, 2015 2:41 pm
Hi Guys,
in beginning: before I decide create this topic, I already read lot of tutorials and threads, how to connect ESP8266, but nothing helpes.
This is my setup:
After FTDI was connected to my PC, baud rate was set to 9600 but ESP was not responding. Then I read about troubles with enter character but using Enter + Ctrl-J don't helps (AT command was set but not response received). I tried several baud rates recommended on internet but without luck. Do you guys have some advice what I'm doing wrong?
Thanks a lot.
This is my setup:
- FTDI 3.3V
ESP module is soldered to breakboard, all connections are working and tested
FTDI.VCC is connected to VCC, CH_PD
FTDI.GND is connected to GPIO15 and GND
FTDI.TX is connected to TX
FTDI.RX is connected to RX
other pins are not connected.
Thanks a lot.
