ESP8266-01 problem with GPIO1 internal pullup
Posted: Tue Jan 30, 2018 8:28 pm
I use a ESP8266-01 behind a wall switch to read several switches and convert them to mqtt messages.
problem is that I want to use GPIO1 (normally TX output) as input. I initialize it as input with pullup active.
pinMode(1,INPUT_PULLUP);
The wall switch is connected to bridge the GPIO1 to GND when pressed.
The crazy thing is, that for two weeks all worked fine. Suddenly that changed: the input is now floating and changes between 0 and 1 all the time when switch open. when I press the switch, thus connecting GPIO1 to GND, the esp8266 correctly reports 0 constantly.
Question: Is it a known behaviour that internal pullup is not reliable? I will have to try to mount external pullup.
Is it a problem to use GPIO1 as input? I checked the ESP8266-01 board and there is not pulldown or pullup resistor mounted.
I also tried several things in software: removed all serial commands, and tried
Serial.setDebugOutput(0);
also tried
Serial.swap() ; to remap serial function to other GPIOs
also tried
pinMode(1, FUNCTION_3); // swap from serial TX to GPIO mode
but nothing helped.
Is the GPIO pullup blown for any reason?
thanks for help.
also tried
also tried
but nothing helped.
thanks for help.
