https://www.aliexpress.com/item/ESP8266 ... 0.0.rviZwX
I've tried various/several:
pinMode(N, OUTPUT);
digitalWrite(N, 0[1]);
with no joy. What should "N" be? I've can "curl http://IP/on[off]" and the 8266 responds/blinks but no relay change.
Tks
Explore... Chat... Share...
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is active low on the ESP-01)
delay(1000); // Wait for a second
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
delay(2000); // Wait for two seconds (to demonstrate the active low LED)
}It takes about 20-25 seconds for home assistant c[…]
