I have a TV lift which will go up and down using a remote.
I want to add the Sonoff Mini switch so I can raise and lower the lift by commanding Alexa and google. This should be possible although I am a bit of a novice and it is unclear where this needs to be wired in
In the photos you can see my mistake, power is going into the Sonoff however it will not interact with the lift.
If anyone has advice on how to make this work I would appreciate it!
Thanks
