Page 1 of 3
Prototyping Double Sided PCB Board ESP8266F & ESP32 modules
Posted:
Sun May 27, 2018 10:01 pm
by whats_up_skip
Is anyone using these relatively new [ur=https://www.aliexpress.com/item/5x7CM-50x70mm-Double-Side-Prototype-PCB-Board-Breadboard-Protoshield-For-Arduino-Relay-ESP8266-WIFI-ESP-12F/32840964903.htmll] double sided prototype PCB boards for ESP8266F & ESP32 modules[/url]?
I am just looking for inspiration and tips on using these, particularly layout and basic components used.
Re: Prototyping Double Sided PCB Board ESP8266F & ESP32 modu
Posted:
Mon May 28, 2018 8:07 am
by rudy
I have bought some of the bigger one (larger board) and used one for a ESP32. They are cheap and an useful way to make a development board with the items you want on it. I think it could have been done better. Like connecting some rows of pads for the 3.3 volt power. It has a relay footprint that might be useful for some people.
They are far from ideal, but they are useable. I think the bigger board is better as it gives you more room to add things. And if you need to fit it into an enclosure you can always cut it down. The difference in price is small.
Posted:
Mon May 28, 2018 3:41 pm
by whats_up_skip
What did you use to power it?
How did you program the ESP32, that is on the board once you solder it on or prior to this?
Posted:
Mon May 28, 2018 4:23 pm
by rudy
All of my modules are ESP-12. None of the PCBs that I have these on include USB to serial chips. I use external USB-Serial converters. I rarely use the 3.3 volt output from the USB to serial converter. The converters I use have sufficient power for driving these modules. (not FTDI 3.3v outputs)
Most of my modules include a 3.3 volt linear regulator. On the board (like the above board) I have included a through hole 3.3 volt regulator. I always put the regulators as close as I can to the VCC and GND pins of the modules.
I'll try and take a picture and post it later.
