I'm facing problems in order to use I2C in a Single ESP 8266 12 and 07 Chip. I'm not having this problem if I connect the I2C sensor to NodeMCU ESP 12, anyone faced this problem too?
Here is the configuration with problem:
- ESP8266 12 or 07 Chip (Not NodeMCU / Chip soldered direct on PCB);
- SHT20 connected to ports GPIO4 and GPIO5 (04 - SDA and 05 - SCL);
- Power to SHT20 comes from the same VCC and GND lines;
Configuration that works:
- NodeMCU ESP 12;
- SHT20 connected to ports D1 and D2;
- Power to SHT20 comes from the same VCC and GND pins from NodeMCU;
Both of configurations use this I2C Scanner Code:
#include <Wire.h>
void setup()
Wire.begin();
Serial.begin(9600);
Serial.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
}Maybe the NodeMCU has a Pull Up, Voltage Divider, because since the ESP are the same and the ports are the same, this problem is something to blow the brain trying to solve and understand...
