Also another weird problem, is that i was working working with the baudrate set on the arduino IDE settings on 115200, and so is the Serial.begin, that is also set to 115200, however i can only read properly the continuous dot that is contained in the while loop "........." when i set it to 74880, which another thing that i was trying to understand. I also forgot to mention that it keeps spamming dots but does not connect at all.
And to conclude, my problem resumes in not being able to connect to any wifi i've tried, i tried my friend's home and also 4g, both did not work, here's the code, which we tried first:
char* ssid = "Net Wi-fi";
char* password = "testingtest";
WiFi.begin(ssid, password);
while(WiFi.status()!=WL_CONNECTED)
Serial.print("Conecting");
Serial.println("");
Serial.print("IP:");
Serial.print(WiFi.localIP());
void loop(){
This was the original try, using the arduino sketch example:
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
const char* ssid = "Net6271";
const char* password = "megaman";
ESP8266WebServer server(80);
const int led = 13;
void handleRoot() {
digitalWrite(led, 1);
server.send(200, "text/plain", "hello from esp8266!");
digitalWrite(led, 0);
void handleNotFound(){
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void){
pinMode(led, OUTPUT);
WiFi.mode(WIFI_STA);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
if (MDNS.begin("esp8266")) {
Serial.println("MDNS responder started");
server.on("/", handleRoot);
server.on("/inline", [](){
server.send(200, "text/plain", "this works as well");
server.onNotFound(handleNotFound);
server.begin();
}void loop(void){
server.handleClient();
Board setting: Generic ESP8266 Module.
Crystal Frequency: 40MHz.
Flash Frequency: 80Mhz.
Upload Speed: 115200.
Flash Mode: DIO.
Flash Size: 512k no SPIFFS.
pls help.
