I'm not a technical guy so sorry for my basic explanation:
my WeMos D1 Mini (3.3V) is powered by a LiPo (18650) which is fed by a SolarPower (6v, 6W).
The battery charges ok via a TP4056 (with protection).
The WeMos D1 Mini is put in DeepSleep (it wakes up every 8 seconds (testcase
D0 is connected to the RST-pin
I put a 100K resistor to the A0-pin so I can read out the Voltage of the battery
Data is send to the Blynk-app
Everything worked ok until the battery got too low: WeMos stopped (as expected
After I manually detached and attached the (same) battery, WeMos boots up again and everything works as before.
Am I missing something? Does it need a sort of Push and if so: how?
Thanks for any help!
