NodeMCU deepsleep power saving
PostPosted: Wed Oct 24, 2018 3:28 pm
by cusaro
Hi,
there are a lot of guides on how tos save power with a NodeMCU v1.0. I happen to have v0.9 lying around. I have no issues with them so I'd like to use them for a battery powered project.
Any ideas or instructions on how to achieve a minimal power consumption with those boards or maybe don't they need any mods?
Thanks!
Re: NodeMCU deepsleep power saving
PostPosted: Thu Oct 25, 2018 3:59 am
by QuickFix
A NodeMCU is a development board, made for convenience, not efficiency.
The NodeMCU has more peripherals on-board than just the ESP: it also includes a USB to serial convertor that also draws (a lot of) power.
If your goal is to create something that is battery powered, you use the NodeMCU to develop your hard- and software and then pour that into a design of your own using a bare ESP-12 module accompanied by only the necessary components.
Even the on-board blue LED on the ESP-12 module uses power, so to efficiently use every drop of juice in your battery, you would want to remove that LED as well.
PostPosted: Thu Oct 25, 2018 5:59 am
by cusaro
Thank you.
I will use then the ESP8266 directly :)
