UPDATED V3!!! PCB ESP-07 or -12 breadboard adapter.
Posted: Wed Mar 04, 2015 3:24 pm
Hey guys! I made a PCB for the ESP-07 and ESP-12 modules, that converts 5V to 3.3V where needed and it has a button to get into flash mode (pulls down GPIO0 to GND) and has pull- up -down for all the needed pins. A choice to pull down the rx or tx pin to 3.3V (sometimes they seem to be switched on the module) , all pins broken out to a" ** breadboard compatible" header and a led for power indication.
**This board is too wide to fit a normal breadboard. You need 2 breadboards, or dupont cables.
The board is singlesided so easy to make at home.
The Voltage regulator is an AMS1117 wich should be the same as the (used in eagle) LM1117.
All components are SMD. If there is enough interest, i can make some component kits (without pcb).
THIS BOARD IS FREE FOR PERSONAL USE AND MAY NOT BE SOLD OR MASS PRODUCED WITHOUT MY PERMISSION!
*THIS BOARD NOW HAS BEEN TESTED!!
EVERYTHING WORKS AS IT SHOULD.
***UPDATED TO V3 !!!
Here is the new design (V3) with the diode D2 removed. (Due to inconsistend ground planes)
Eagle files are attached incl. libraries here:
(CURRENT VERSION V3)
(OLD VERSION V2)
removed...
(OLD VERSION V1)
removed...
(OLD VERSION V2)
removed...
(OLD VERSION V1)
removed...
